use (meshpoint-config)
         Uses a QoS (Quality of Service)
            policy defined specifically for meshpoints. To use this QoS policy, it must be
            defined.
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
      Syntax
         use [aaa-policy <AAA-POLICY-NAME>|meshpoint-qos-policy <MESHPOINT-QOS-POLICY-NAME>]
      Parameters
                        <MESHPOINT-QOS-POLICY-NAME> |
                     Configures this meshpoint to use a predefined
                        meshpoint QoS policy
                           -  <MESHPOINT-QOS-POLICY-NAME> – Specify the meshpoint QoS policy
                              name (should be existing and configured).
                     | aaa-policy <AAA-POLICY-NAME> |
                        aaa-policy
                           - <AAA-POLICY-NAME> – Specify the aaa-policy name (should be
         nx9500-6C8809(config-meshpoint-test)#use meshpoint-qos-policy test
         nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
 description "This is an example of a meshpoint description"
 meshid TestingMeshPoint
 shutdown
 beacon-format mesh-point
 control-vlan 1
 allowed-vlans 1,10-16,18-23
 neighbor inactivity-timeout 300
 data-rates 2.4GHz bgn
 data-rates 5GHz an
 security-mode psk
 root
